Old 01-11-2022, 09:06 PM   #1
Hiro
Drives: 2007 Hatchback Auto
No crank non-starter/solenoid issue Help PLZ
Went into a ditch then have let the car sit ever since, the car hasn't run for a year now. I don't know if I turned it over at all after the wreck at all which doesn't help to know if something was damaged then.
I hit the ground and a big log pretty hard but other than the bumper and radiator things look good. The shift lever on front of transmission was bent and shift cable broke off lever, after bending it back I am able to move it into park but with no change to start condition.
I know there are probably several things that could cause this, here is what I have done so far...
New battery and no crank or click, engine does crank when supplying 12 volts directly to solenoid terminal (small signal wire).
Tested shift lever neutral safety switch, terminals have continuity when in park position and non otherwise so looks functional to me.
Tried starting with shift lever in park/neutral positions and with brake on.
Checked fuses ( I think i found them all).
Checked Starter and Ignition Relay they are good.
Any help would be appreciated, it would really be nice to get my Yaris going again to save money on gas.
Thanks in advance,
Hiro.
Pictures of how the car looks now and of transmission shift lever/neutral safety switch:
Hiro is offline   Reply With Quote
Issue where dashlights either turn on or fade on when car off razingman DIY / Maintenance / Service 0 01-17-2021 12:24 PM
Random No Start Issue Darkhorse6 DIY / Maintenance / Service 6 05-11-2016 12:46 AM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
Minor issue with NST crank pulley at takeoff YarisSedan Performance Modifications 0 05-12-2009 01:06 AM
