Old 01-16-2022, 09:52 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Scratches on engine after installing belt
I've installed a belt on a 2015 Yaris and have some superficial scratches from prying. I've installed and removed this belt and tensioned it when the car was bought 5 years ago. It still didn't look too bad but I had a Bando ones I ordered a few years ago but didn't install, till today.
I have some scratches on the block and head, some under that coolant plug with the Allen head. Don't know it's name, but I was a little worried since it looks thin. Not really visible on camera. I didn't pry hard enough to break anything. But finally figured out the right spot after not doing it for years.
xdarkxfirex is offline   Reply With Quote
Old 01-19-2022, 07:54 PM   #2
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
That should be just fine that allen head is a filter for the VVTI solenoid. You should not have a single problem there is way more than enough metal there you arent gonna hurt a thing with some small scratches like that.
Cletus Garfunkle is offline   Reply With Quote
Old 01-20-2022, 06:33 PM   #3
xdarkxfirex
I used to have an older Yaris with the same setup minus the AC compressor. This one was giving me a harder time with moving the alternator. The place I worried about was where that hollow tube is. Right under I had some scratches but not too bad
My main concern was that if there were any micro cracking that could get worse
2015, belt, serpentine
Oil change shop says alternator belt is cracked RMcG DIY / Maintenance / Service 19 05-02-2018 07:38 AM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
