Old 02-09-2022, 03:55 AM   #1
amaterasu
Drives: 2006 1.3c Automatic
Car drives fine on Friday. Today it wasn't turning on (video). Then it did
Hi all
I drove the car fine all Friday.
Today (last night) I tried to turn it on and you can see what happened in the video (you might need to unmute)
https://imgur.com/a/lALGK5B
I went upstairs, came back, played with it a bit more, and then it eventually started.
Any ideas?
Year: 2006
Make/Model: Toyota Yaris
Mileage: 92000 miles
Engine size: 1296 cc
Transmission Type: Automatic
amaterasu is offline   Reply With Quote
Old 02-09-2022, 08:13 PM   #2
CB900F2
Drives: 08 Sedan
Battery....
Do a load test on the battery
CB900F2 is offline   Reply With Quote
Old 02-10-2022, 03:37 AM   #3
amaterasu
Originally Posted by CB900F2 View Post
Battery....
I've checked the battery and it's the correct voltage
Old 02-15-2022, 07:19 PM   #4
sh0rtlife
voltage is not CCA(cold cranking amps), you can easily have a 12-14v battery that has .5 of an amp in it which wont even run a headlight...12v on a battery does not mean the battery is good
you need to LOAD test the battery, heck if the car wont start, clean the terminals of the batter and tighten it back up, re-test, if it wont start..
the only "free" load test i know of to try is simple enough..flip your wipers up off the glass, turn the key on, and turn the heater on full blast, and listen to it, now turn on the wipers, did it slow?..now turn on the headlights, did it slow now?, hit the brakes and flip on the hazzards, if this makes the heater sound slowed down or "pulse" with the flashers then youve got a low amp weak battery in need of replacement
Old 02-19-2022, 02:02 AM   #5
IndestructibleYaris
Definitely do some diagnostics on the electrical system
IndestructibleYaris is offline   Reply With Quote
enobmort42 - Photo-Scavenger Hunt! enobmort42 Photo-Video-Media Gallery 9 03-05-2009 10:52 PM
CtrlAltDefeat - Photo-Scavenger Hunt CtrlAltDefeat Photo-Video-Media Gallery 0 03-04-2009 02:14 AM
Black Friday Bob_VT Off-topic / Other Cars / Everything else Discussions 70 11-29-2008 07:07 AM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
