Old 02-20-2022, 01:31 PM   #1
jussih
Drives: Yaris D4D
1ND-TV not running after engine replacement
Hello.
I have problem with my 2007 yaris D4D. I change complete engine, original engine has huge oil consumption but it starting and running ok. New engine is 2005 model, but every parts looks same. When i pull old engine out, i pull ecm wiring connector out.
New engine in, all wirings back. cranks good, but not run, no smoke. Fuel handpump is hard. All grounds are ok and wiring.
Check DTC techstream diagnostic tool
P0340, P0045, P1271, P0089, P1228, P0252
Cleaning DTC:s not possible, they come back.
I wonder if ECM broken? When i pull ECM connector out, battery has allready disconnect.
Will anyone have any opinion on the problem?
Best Regards
Jussi
jussih is offline   Reply With Quote
Old 02-20-2022, 02:11 PM   #2
Dieselking
Drives: 07 1,4d diesel
What are the codes?
not just the numbers, but what does they say?
Dieselking is offline   Reply With Quote
Old 02-20-2022, 02:13 PM   #3
I'll pretty much guarantee you the ECM is not compatible with the newer model year engine. Yes, they look the same, but electronics not quite.
Old 02-20-2022, 02:51 PM   #4
jussih
Drives: Yaris D4D
Hello
P0340 camshaft position sensor “A" circuit
P0045 Turbocharger / Supercharger Boost Control Solenoid Circuit / Open
P1271 Fuel Regulator Circuit Malfunction (EDU Drive)
P0089 Pressure Control Valve Plausibility to Consume Current High Intensity
P1228 Injection Pump Fuel Metering Control "A" Range / Performance (Cam / Rotor / Injector)
P0252 Injection Pump Fuel Metering Control "A" Range / Performance (Cam / Rotor / Injector)
Old 02-20-2022, 02:59 PM   #5
Dieselking
07 is a nlp90 yaris
05 is a nlp10 yaris
The engines are not the same.
How much did you swap over from your 07 engine?
Old 02-20-2022, 04:32 PM   #6
Originally Posted by Dieselking View Post
07 is a nlp90 yaris
05 is a nlp10 yaris
Those are chassis codes, not engine codes. Different chassis models can have the same model engine. I do stand behind my comment that engine management is not the same between the two model years being dealt with here.
Old 02-20-2022, 09:59 PM   #7
jussih
Drives: Yaris D4D
This engine is not nlp 10 engine. All components/brackets looks same. Turbocharger is same.
the next option seems to be to replace the old engine electrical components with a new one, or at least compare their part numbers with each other
Old 02-22-2022, 11:42 AM   #8
jussih
Drives: Yaris D4D
Problem solved. My mistake, im only measurement fuses continuance. Problem is bad contact and corrosion on edc2 fuse. No dtc and engine run.
thanks to everyone
2007 sedan fuel pump not running and check engine light nitrus10032 DIY / Maintenance / Service 23 08-23-2025 12:09 PM
Engine turns over but doesn’t start on a Yaris VVTi YarisVVTi2002 DIY / Maintenance / Service 50 03-30-2025 08:27 PM
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
