Old 03-08-2022, 12:54 PM   #1
zrwon
zrwon's Avatar
Drives: 07 5 door hatchback
Radio wiring problem
12v power was dead, I removed the blue wire from the 12v power source because the wire failed somewhere and I ran a wire with an online fuse to a good 12v power source and it solved my problem. I had lost me flasher signal a year ago for the same reason.
Aftermarket remote start installers had poked a hole in the insulation of the wire and the wire corroded until it cut out, luckily I found that one and was able to repair it but the blue one for the radio, I couldn't find it, so I ran a new one.
zrwon is offline   Reply With Quote
Old 03-08-2022, 01:44 PM   #2
Typically, when people question the "blue" wire and it's purpose, they are referring to the power wire for the antenna. Since we have an amplified antenna in these cars, it requires a power feed coming from the head unit. If this is indeed the wire you are referring to, then you will not find an associated fuse.
strange radio problem (rare) rtom In Car Entertainment + Electronics (audio / video / alarm) 3 02-04-2011 01:58 PM
Radio Reception Problem The Shape In Car Entertainment + Electronics (audio / video / alarm) 3 09-20-2010 06:32 PM
Radio ON at start - problem miszelos In Car Entertainment + Electronics (audio / video / alarm) 10 09-07-2010 06:59 PM
Mounting a CB radio somewhere Sodium Duck Cosmetic Modifications (Exterior/Interior) 1 03-06-2009 01:50 AM
AM Radio fine FM radio non-existent!! sharkalos In Car Entertainment + Electronics (audio / video / alarm) 0 04-30-2007 01:51 PM
