Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Great Lakes
Old 04-01-2022, 09:06 AM   #1
popperette
Drives: 2018 Toyota Yaris IA
Brake Torque specs for 2018 Yaris IA
Hello,
My niece has a 2018 Toyota Yaris IA and wants me to do a front break job. Does anyone know what the caliper bracket and Caliper pin bolts torque specs are?
I found that the 2007 and the 2010 were the same at 79 ft/lbs for the bracket bolts and 25 ft/lbs for the pin bolts. Just curious if those numbers have changed for the 2018.
Thank you.
popperette is offline   Reply With Quote
Old 04-01-2022, 02:21 PM   #2
I doubt very much they've changed. Even if they did, it would be by an insignificant amount. Go with what you got.
Rear brake disks sliding bolt torque Keymaster DIY / Maintenance / Service 6 04-12-2016 03:53 AM
Yaris with rear disc brake from factory? tamrat DIY / Maintenance / Service 18 01-19-2016 09:08 AM
Will XA XB's brake line fit our Yaris?? AlainMikli Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-04-2009 01:22 AM
