Old 05-06-2022, 01:38 PM   #1
Pinchlite
Drives: 2007 yaris HB
angle grind off lower alternator bolt?
The retard that replaced the alt overtightened the long through bolt
Someone recomended doing this as only/last resort...mine is seized on.
I need to remove to replace water pump....its overheating...I doubt its the water pump though...but thats another issue.
Pinchlite is offline   Reply With Quote
Grind, Grind, Grind 2o6 DIY / Maintenance / Service 16 06-26-2013 07:24 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
Lower Grill Replacement Idea (feeler) counterfiend Cosmetic Modifications (Exterior/Interior) 7 09-24-2009 08:40 PM
