Old 05-18-2022, 07:12 PM   #1
Gilbertsmith
Drives: 2008 Yaris hatchback
Instrument cluster flickers while driving
Hey there! I've got a 2008 base model hatchback here, and for the last year or so I've noticed every once in a while (maybe weekly) the instrument cluster will flicker while I'm driving.
It looks like the backlight goes off and on a few times, like I'm adjusting the dimmer knob, which is always cranked all the way up and "locked" in that notch at the top. The gauges don't misbehave, the LCD stays lit, it's just the backlight by the looks of it, but all of the backlight, not in sections or anything.
I've had the whole cluster out and checked the connections and it all looks fine from what I can tell. Usually it'll flicker for a few seconds and then be fine for another few days.
Any thoughts where I should be looking for this? No other electrical problems (or any problems really) other than this
Thanks!
Gilbertsmith is offline   Reply With Quote
Old 05-19-2022, 01:54 AM   #2
sh0rtlife
outside of pulling the cluster apart for inspections as well as swapping the switch out for one from a wrecker
sadly the clusters are not really bolted down..or..atleast not bolted to anything remotely solid so they are in a sense prone to alot of internal vibrations
Instrument Cluster Question thebark Cosmetic Modifications (Exterior/Interior) 1 09-01-2016 03:47 PM
Willing to trade 2010 MPH liftback cluster w/tach w/ABS for cluster w/tach wo/ABS Jabro Willing to Buy by private party 4 12-21-2012 06:34 PM
Moving instrument cluster? Chris333 Cosmetic Modifications (Exterior/Interior) 18 01-12-2012 10:38 PM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
Instrument Cluster upgrade? ubetiam Cosmetic Modifications (Exterior/Interior) 6 06-27-2006 09:50 PM
