Old 05-26-2022, 06:52 PM   #1
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
Stock Ecu limiter changed for 10$
ONLY TESTED WITH 1st GEN ECHO AND AUTO TRANS ECU.
Sorry if this was known haven't seen it on the search for the 5 min I looked.
If anyone can find me some datasheets on the IC's send them my way I'd love to try and get some data off the damn things.
TLDR: Buy 19.2Mhz quarts crystal for 8k rpm limiter solder it to ECU. Only tried with auto ECU should work with manual trans too.
Just a couple warnings this may cause weird issues with electronics from what I've been told by an old boomer. I have only tested it for a couple days seems to run and drive fine with little changes. Will update after awhile of driving.
Found some Russian forum he did it with a 1SZ-FE. It seems to work just fine with a 1NZ-FE and U340E.
This will change the rev limiter and make the trans shift at a higher rpm don't have a tac at the moment to confirm it but it used to limit at 70mph in 2nd gear now it limits at 80mph.
You will need new quartz crystals. stock are 16Mhz. I bought 19.2Mhz.
First find the crystals on the board and desolder them
Next Solder new crystals on I have 19.2Mhz.
Finally Go Test.
Cletus Garfunkle is offline   Reply With Quote
ecu, limit, limiter, rev, stock
New Engine Management System offered for the 1NZFE Dezod Forced Induction Forum 51 06-16-2011 11:33 AM
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 11:48 AM
Converting from Custom Wheels back to stock!!! daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-23-2010 09:45 PM
Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? trini_per4mance Forced Induction Forum 19 05-06-2009 02:18 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 01:30 PM
