Old 06-01-2022, 01:34 PM   #1
TerryAdams
Steering Not As Responsive
MK2 Yaris 08
Few months back I had the top mounts and coils done for the front.
Since then I feel I have to turn more than I used to. Lets say for a parallel park I used to turn the wheel one turn to the left. I now have to turn about one and a quarter.
Going round a 90 degree corner I used to turn about half a turn, now I have to turn a full turn.
Today I had the tracking done, and it seems to have changed again, to the point where I have to turn even more.
This is more noticeable at low speeds, at higher speeds ( 45 to 70 mph ) it is nice and responsive.
Any ideas what could cause this ?
I do occasionally get a clicking sound from the steering wheel ( This started well after the " lack of responsiveness" so probably not related ). I have heard is a common thing in Toyotas, mostly been alleviated by lubricating the middle part of the steering column. Said clicking sound is usually only when parking at low speeds, and seems to disappear if I occasionally adjust the wheel up and down a few times.
The column itself looks tight, and has no play.
TerryAdams is offline   Reply With Quote
Old 06-01-2022, 07:20 PM   #2
ex-x-fire
Some of the steering shaft u joints might be seized up. You need to remove it and feel for smooth joint flexing.
Old 06-03-2022, 02:22 PM   #3
sh0rtlife
is it possible you have electronic assist and not power steering..if so..in theory the power motor could be getting weak?>
No power steering on '08 Yaris after airbag recall done madradjessica DIY / Maintenance / Service 14 12-18-2018 08:14 PM
DIY aftermarket steering wheel install with horn and airbag delete tmontague Performance Modifications 19 11-30-2018 12:19 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Steering wander, adjusting EPS assist Snubba Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-22-2012 05:39 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
