#1 |
![]() Drives: 2008 Yaris Hatchback Join Date: Sep 2021
2008 Yaris 2-Bar Fuel Gauge Issue
Greetings,
I have a 2008 Yaris HB with 140K miles that has the 2-bar fuel gauge issue. Gas ran out at 2-bars already. I see that the fuel sending unit might be the issue. Looks like the OEM fuel sending unit is less than $100. Not sure how much it would cost to get it replace in So. Cal. I see the OEM fuel pump is about $300. Replacement (non-OEM) fuel pumps seem to be around $100. My son is going to take it up to college and I rather have everything working. - Replace the sending unit only with the OEM one - Replace the whole fuel pump with a non-OEM fuel pump - Replace with the OEM fuel pump. All 3 options should cost the same labor. The last option would be the most expensive. I know the other suggestion would be to watch the trip meter, etc. Please advice. Thanks, GHTech |
![]() ![]() ![]() ![]() ![]() Drives: 2007 5dr canadian import Join Date: Dec 2016
its actualy a simple swap ..and i thought there was an in floor access to it under the rear seat
but yeah your sender is bad without a doubt, as for the pump, unless its sludged up or you make a habbit of running the tank neer empty all the time should be fine, tho i totaly get doing preventitive maintinance |
#3 | |
#4 |
gotta love stealership price gouging
| Tags |
| fuel pump, fuel sending unit |
| NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 08:50 AM |
| 2018 Yaris SE 5MT - T-Sport w/Valvematic! | atomic_hoji | Performance Modifications | 130 | 02-23-2019 12:56 PM |
| Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 09:55 PM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 12:03 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
