Old 06-13-2022, 05:15 PM   #1
ricardo-cr23
Drives: Toyota Yaris 2007 1.5L V4
Yaris 2007 Rear Brakes issue
Hello!
I have a Toyota Yaris 2007 Sedan 1.5L with ABS brakes. The issue I have is that I have to adjust the rear brakes really often. I start noticing they loose when the parking brake lever starts loosing up.
Looks like it only happens on the left side (I disassemble the interior, and I look at the parking brake pull rod sub-assembly, and left side one is loose).
What I have done so far:
- Replaced whole drum, brake shoes, wheel brake cylinder, springs, the brake shoe strut set.
- Adjusted parking brake lever nut
- Bled the brakes, making sure no air is in the system (not sure if this has something to do with it)
I took the car to government annual inspection, and the report said there is a braking difference between rear brakes.
My mechanic told me that it could be one of the valves that inject brake fluid, but I am not sure about this.
What can I do to find the faulty part?
ricardo-cr23 is offline   Reply With Quote
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
