Old 06-20-2022, 12:16 PM   #1
Fandango
Drives: 2006 Yaris
Thumbs down 2006 Yaris will not start
Basic 2006 keyed model
I turn the key and the car acts as it has a dead battery. No lights no dings no attempts to start.
I will turn the key back, and then to start again, and nothing happens
I will repeat this until it actually connects and then it starts no problem
I dont think it's a poor battery connection because the lights would still come on and it would ding at me. Plus then why would it all of a sudden start flawlessly as if suddenly the battery was max charge?
Personal theory is that the key mechanism in the steering wheel is broken.
But I am no mechanic. Any thoughts? Thx for your time people!
Fandango is offline   Reply With Quote
Old 06-20-2022, 01:44 PM   #2
Your symptoms do sound like possible corrosion on the battery terminals. While you may "think" the connections are good, for the minimal time/effort to clean the posts and clamps, I would certainly undertake that as a first step.
Old 06-20-2022, 06:30 PM   #3
bronsin
bronsin's Avatar
A bad ignition switch is certainly a possibility. Why don’t you have it changed and report back?
Old 06-22-2022, 12:48 PM   #4
sh0rtlife
start by cleaning the battery terminals, thats always #1 when it comes to electrical faults, #2 is, how old is the battery and what condition is it in....the yaris has an odd setup with a semi auto start feature and if the battery is weak it just doesnt bother to try
if both #1 and #2 check out, then yes the ignition switch itself is the next in line to check/test....the other option would be a transponder/antitheft if equiped..itcould be weak and do the same thing
2006 yaris, dead battery, starting / ignition
DIY: Adding AUX input to 2006 french Yaris - W58824 sven337 DIY / Maintenance / Service 4 04-17-2022 12:59 PM
yaris wont start tkhtx1 DIY / Maintenance / Service 4 02-11-2014 10:08 AM
Thinking about buying a 2006 Yaris Liftback kes New YARIS Purchase Forum 4 07-15-2010 07:34 PM
