Old 06-30-2022, 05:17 AM   #1
Jaybo100
Drives: Yaris 1.5 VVT-i T Sport 3dr
Unhappy Need help with airbag ecu!
Hi there,
I’m new to the forum, just joined in the hope some knowledgeable folk in here can help me as I’m at the point where I might have to scrap the Yaris
So I have a 2003 1.5 VVT-i T Sport 3dr. It recently failed the mot due to the airbag light staying on. The garage told me from diagnostics it was a squib ring problem which I replaced, still the same issue. Got an electrician to check it all out and he’s narrowed it down to the airbag ecu.
Now the problem is I’ve since found out from Toyota that this is an import, and the ecu is some obscure thing that I can’t get hold of anywhere! I’ve tried getting it fixed at an ecu repair place, they couldn’t interface with it for some reason, I’ve tried a pcb repair place who want £200+ just to diagnose the thing. Model number is 89170-0D010.
So in short, I was hoping someone here might have dealt with this before? Or maybe a different model of ecu can fit this model Yaris, one that’s more readily available? Because I’ve searched all over the net and can’t find one. Seems a shame to junk the whole car over an airbag light! Any help much appreciated, thank you.
Jaybo100 is offline   Reply With Quote
Old 06-30-2022, 12:31 PM   #2
sh0rtlife
the question becomes..what country is it in...maybe get another ecu
airbag, ecu, fail, mot
DIY aftermarket steering wheel install with horn and airbag delete tmontague Performance Modifications 19 11-30-2018 01:19 PM
Passenger airbag recall/disable airbag? 47_MasoN_47 DIY / Maintenance / Service 20 11-06-2016 04:36 PM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 02:50 AM
Airbag ECU code 31 - what does it really mean? ajuniper DIY / Maintenance / Service 6 11-30-2014 10:05 AM
2008 yaris sedan airbag... Din get answer anywhere yet... Abk911 In Car Entertainment + Electronics (audio / video / alarm) 3 04-09-2013 12:33 AM
