Old 07-09-2022, 12:37 PM   #1
k98shooter
Drives: 2012 Yaris Hatchback 3 door
Should I replace coolant pump at 130K miles?
I have entire front removed, including radiator (crash). I have no idea about vehicle history - bought it wrecked. I am tempted to replace water pump, as it easily accessible at this stage of repair. The question is: Should I bother? I read these cars go 300k and even more on original pumps.
k98shooter is offline   Reply With Quote
Old 07-09-2022, 03:13 PM   #2
2012 does not have a history of problematic water pumps. My '06, which does have the pump some have reported issue with is still problem free after 380,000km. Leave yours in there.
Old 07-10-2022, 01:31 PM   #3
bronsin
bronsin's Avatar
Leave it alone I agree
Old 07-10-2022, 04:57 PM   #4
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
If it ain't broke, don't fix it.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 07-11-2022, 09:40 AM   #5
esse10
Drives: 2009 yaris 2 door
leave the pump
My 2009 has 295k miles with the original water pump. I had to replace the gearbox this past weekend though.
Old 07-12-2022, 02:08 AM   #6
komichal
My 2007 had the original water pump replaced in 2015 as it was pink all around.
According to the authorized service center this was common issue for Yaris with this engine (2SZFE).
No problem since then.
I would actually say - if it is so nicely accessible now then I would go for a change (for some quality brand!). 10 years of service is quite a lot.
Old 07-12-2022, 11:53 AM   #7
sh0rtlife
130k miles on a an item thats little more than 2 bearings and a seal is nothing, leave it be...if the gasket shows signs of color or weaping then by all means change it
Old 07-21-2022, 08:16 AM   #8
Definitely leave it, if it has an issue down the road then change it out. It can be done with the engine in place it just is a bit more finicky.
Old 07-21-2022, 07:24 PM   #9
ex-x-fire
I would replace it. Get a good quality Aisin.
Old 08-12-2022, 02:02 AM   #10
IndestructibleYaris
350k original everything except for a personally rebuilt alternator. These cars usually need nothing but oil
IndestructibleYaris is offline   Reply With Quote
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 08:05 AM
Khameleon Coolant? LilyOfTheYaris DIY / Maintenance / Service 18 04-08-2014 10:27 PM
How many miles before you had to replace brakes, tires, battery, etc ... Yaris_Fan DIY / Maintenance / Service 53 01-15-2013 11:52 AM
Water Pump gone at 33700 Miles weaver615 DIY / Maintenance / Service 56 02-19-2011 02:17 PM
