Old 07-19-2022, 12:55 PM   #1
Suey 1958
Drives: 2007 toyota Yaris
2007 Yaris---235,000 miles
I have put all the miles on this car with oil/filter changes every 5k miles.
I have gone through a starter, alternator, a couple of fan belts.
I am a senior driver, so it has not been abused
The car runs perfect, but I know it won't last forever.
The engine has never been into or even had a wrench on it.
QUESTION IS: Is there anything I should be concerned with, or check? inside the engine? Such as cam chain/or belt, Etc.
Just wondering how long these last??
Thanks
Suey 1958 is offline   Reply With Quote
Old 07-19-2022, 07:22 PM   #2
ex-x-fire
I'd have the spark plugs changed. Make sure the water pump is dry. Toyotas will usually have crusty red stuff below the pump when it's in the first stage of leaking.
Old 07-19-2022, 11:28 PM   #3
sh0rtlife
plugs and fuel filter would be the ones id do as preventative..do an oil change on the trans..and filter if its an auto
outside of that my only concern would be brakes and wheel bearings..possibly balljoints and tie rods
Old 07-20-2022, 07:53 AM   #4
Suey 1958
Thanks for your suggestions !! I can handle the plugs, brakes, and filters myself but not sure how difficult a water pump would be, I have not seen any leaks yet but I have been concerned about it.
Best car I have ever owned, Thanks Again !
Old 07-20-2022, 12:37 PM   #5
bronsin
bronsin's Avatar
If you have been changing the oil like you say drive the car until it dies. It could last for another hundred thousand miles or even more. You didn’t say anything about the air filter I hope you’ve been changing that.
Basically if it’s not broke don’t fix it! You don’t have to worry about the timing chain if you’ve been changing your oil.
Old 08-03-2022, 09:33 AM   #6
gilsaluki
Drives: 2007 Toyota Yaris 3DR
I too have a 2007 with that many miles. Did have a fuel pump sensor (fuel level) go out. I chased my tail on that one. My hatchback lift bracket broke. Fixed it thanks to Yaris World member suggestion. Changed oil every 3.5K miles. Changed Auto Xmission oil/filter twice. Changed the plugs, all easy. Never flushed the brake fluid. Changed pads once. Normal routine maintenance. Best car ever. No wonder Toyota got rid of it. They last too long.
gilsaluki is offline   Reply With Quote
2007 Yaris 42000 Miles hatchback simsona87 General Yaris / Vitz Discussion 5 05-27-2018 03:22 AM
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
2007 4 door Yaris 5 spd for sale in NY (~59k miles) dejital Cars for Sale by private party 4 09-17-2011 02:05 PM
