Old 07-31-2022, 11:35 PM   #1
Dbyq1994
Drives: 2020 yaris
Unhappy 2020 Torque specs (for front axle nut)
I have a 2020 yaris and I'm having the hardest time finding any factory torque specs for anything. Specifically I think my front axle nut is loose but any info on how I can get the other specs would be amazing! I can't find a maintenance manual or anything for it, I've also looked for mazda 2 specs and that's not any better.
Dbyq1994 is offline   Reply With Quote
Front hub Axle nut torque process esse10 DIY / Maintenance / Service 2 05-19-2022 04:28 PM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
Front Lower Arms and Ball Joint Torque Specs for 2012 Toyota Yaris LE Hatchback ToughGuy DIY / Maintenance / Service 0 12-23-2020 08:38 PM
TRD Delrin Rear Axle Bushing Collars tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-15-2019 07:50 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
