Old 08-28-2022, 05:18 PM   #1
egf265
Drives: 2007 Yaris Hatchback
HELP! Washer Fluid Reservoir
I’m putting in a new windshield washer reservoir and can’t figure out a part. I’m not even sure what it is for. The reservoir only has 2 holes for the back and front windshield sensors. The only number I can find on the part is Y05 11068.
egf265 is offline   Reply With Quote
Old 08-28-2022, 05:56 PM   #2
sh0rtlife
did you order the correct bottle?..im asking this as there are 2 different units 1 with 2 holes 1 with 3 holes
3holes=front and rear wipers and level sensor
2 holes= front only and level sensor
Old 08-29-2022, 09:35 AM   #3
egf265
I was wondering if that's what it might be, I of course threw out the old one and then came back months later to finally put the new one in. It still works without putting that piece in (must be the level sensor). Thank you!
Inexpensive fix for low windshield washer fluid light stiuck on Toolaholic DIY / Maintenance / Service 5 04-21-2020 02:46 PM
Manual Transmission Fluid Woes tmontague Performance Modifications 4 10-08-2018 09:12 AM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Windshield Washer Fluid Reservoir level romram DIY / Maintenance / Service 2 03-22-2015 04:16 PM
Washer Fluid & Other Questions vaironl DIY / Maintenance / Service 1 11-16-2013 01:25 PM
