Old 08-30-2022, 12:49 AM   #1
CrimsonEclipse
Drives: .
Front Driver Side Seatbelt Removal
I guess it's time to fix my sagging seat belt.
It doesn't retract fully and gets caught in the door and just looks bad.
Are there any tricks for the full assembly removal or is it the standard 3 or 4 bolts to the frame like the older cars?
(I couldn't find any pictures, videos, or manuals)
Should I try to fix the assembly on my own (manually tightening the spring) or is it better to send it in for service?
Or does anyone know where I can purchase a new assembly?
(2011 Hatchback in the USA)
CrimsonEclipse is offline   Reply With Quote
Old 08-30-2022, 12:20 PM   #2
thetut
Drives: 2007 4dr sedan
Try this first at no cost : https://www.youtube.com/watch?v=8XL8QbooM84
thetut is offline   Reply With Quote
Old 08-31-2022, 01:10 AM   #3
sh0rtlife
yeah its a simple remove, 3 bolts and a plug
tho you do need to remove the trim too and the upper "slider" is a lil tricky as you have to pop up the fingers on the button to access the bolt
Help! Right side lower control arm removal RUBBERDIPSTICK DIY / Maintenance / Service 15 12-27-2018 01:29 PM
Water leak to passenger side AND driver side TMR3 DIY / Maintenance / Service 7 05-21-2017 07:19 AM
Driver Side Door Not Open From Out Side DigitalGuy DIY / Maintenance / Service 2 10-17-2016 06:07 PM
Very strange clunking from driver side tire - everything tried so far no go? (2007) KorJax DIY / Maintenance / Service 22 12-09-2014 02:50 PM
Driver Side Wiper Issue justfillingtime DIY / Maintenance / Service 2 02-15-2013 08:08 AM
