Old 10-16-2022, 03:15 AM   #1
yaris2014toyota
Drives: Yaris 2014 2-Door LE
bought used Yaris 2014 hatchback that needs front bumper, how to DIY
I bought a 2014 Yaris Hatchback.
First time Yaris owner.
Seems it was in some sort of accident (see pics).
(In case embedded pics are not visible, they're here:
https://imgur.com/XrMyhCr
https://imgur.com/uNUaVAv )
It's admittedly a risk, but runs well.
It immediately needs a new front bumper. Plus, there were a couple other plastic pieces (one that wrapped around the front right wheel, and another thing that was some sort of bracket on the front right side) that were hanging off the car that I cut with a pair of scissors.
I plan to replace the bumper myself.
My question for you: How do you recommend I go about researching and figuring out what to buy and how to fix it?
Thanks in advance.
yaris2014toyota is offline   Reply With Quote
Old 10-16-2022, 10:39 PM   #2
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
I would just take the bumper off look for a bolt take it out look for clips take them out just simple stuff look at one side look at the other check what's different and does it have to be there if yes find a replacement part either from a part store/dealer or junkyard/ebay. If no just forget about it.
Cletus Garfunkle is offline   Reply With Quote
Old 10-18-2022, 03:41 PM   #3
sh0rtlife
i would assume its similar to the earlier gens, should just be a few push in plasict rivets across the top(expect some under the headlights) and more plastic clips for the iner fender splash shields
the ONLY bolts youll need to remove should be 2 for each headlight and 4 or 5 across the bottom of the bumper that bolts into the bottom of the radiator support, i also belive there are 2 screws on each side in the splash covers
2014, accident, front bumper
Yaris front bumper advice. Pls help jordanyaris2013 DIY / Maintenance / Service 5 09-02-2020 04:32 AM
2012 Yaris Le Front Bumper JDMYaris107 Cosmetic Modifications (Exterior/Interior) 0 01-20-2018 01:26 AM
WTB Used Yaris (2nd gen) original front bumper nicl Willing to Buy by private party 0 08-17-2014 01:43 PM
