Old 10-16-2022, 03:00 PM   #1
PooZapper
Drives: 2010 Toyota Yaris Sedan
2010 Yaris- MAF connecter is bad, looking for full harness
I am looking for the full harness so I do not have to splice the wires, where can I find this? I am getting no voltage from all wires, expect the power cable.
PooZapper is offline   Reply With Quote
Old 10-16-2022, 08:33 PM   #2
remcafee
you want to replace your entire wiring harness for a dead maf signal? dude i would just repair it, good luck finding a ysed loom thats not already having the same issues unless you have money to burn on an $1000 new oem loom
Old 10-16-2022, 09:34 PM   #3
PooZapper
Gotcha. I had no idea what it was even called to begin with 😅 I am a bit of a noon. Ok, I will just buy a new harness and splice it on
I appreciate your tips:)
Old 10-16-2022, 10:22 PM   #4
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
Just a quick thought make sure that the connector you splice on. Before you buy it just cut insolation back to all the wires and make sure you are getting power before the connecter. I'd hate to buy one then have the same problem with a new one.
Cletus Garfunkle is offline   Reply With Quote
Old 10-18-2022, 03:37 PM   #5
sh0rtlife
and you can use the maf section of ANY toyota harness that uses the same plug
i know what it takes to remove the whole harness...and....its an all day job with a full discetion of the dash and engine bay
2010 Yaris cranks but does not start Rob888 General Yaris / Vitz Discussion 3 02-09-2021 04:12 AM
Bought A Used 2010 Yaris Sedan & Customized! us13doolittle New YARIS Purchase Forum 8 10-14-2012 05:16 AM
