Old 10-18-2022, 12:42 PM   #1
sh0rtlife
power window swap 5dr parts?
so ive managed to gather "most" of the pieces to do the swap, ive even installed the fronts, with only a minor issue
im having issues getting the drivers harness, switch and switch plate for a 5dr
for now ive got the 2d harness and switch plate and both fronts working perfectly, ive also managed to snag exactly 1 rear
so the question stands ive got a 5dr, are the rear door units from a sedan the same as a 5dr hatch?, also what about the switch and driver door harness?....i know the trim plate isnt the same but suspect the switch is the same across multiple bodys
ive also heard rumor that some of the prius its the same regulator/motor
Driver's power window auto-down disable? yaris07hb DIY / Maintenance / Service 6 04-01-2019 06:07 PM
FYI: Aftermarket parts from Japan (NCP131) yarisugi Third Gen Yaris General Discussion 26 01-30-2016 06:43 AM
Power window noise birdman DIY / Maintenance / Service 10 09-01-2012 12:11 PM
POWER WINDOW POWER SOURCE IN DOOR PANEL? mrrock DIY / Maintenance / Service 5 03-21-2007 06:27 PM
