Old 10-25-2022, 04:16 PM   #1
ahmad_yaris
Drives: yaris 2007
yaris spark plug order 1-4
Hello,
I have famous p0304 misfire detected.
I wonder is the driver side spark plug one driver side is spark plug 4 ?
ahmad_yaris is offline   Reply With Quote
Old 10-25-2022, 04:41 PM   #2
bronsin
bronsin's Avatar
I think number one is on the driver side, and number four is on the passenger side. 304 means switch the coil with any other one let’s say Number one period start the engine know if you get a 301 code you know that coil was bad and you need a new coil
Good luck and tell us what happens!
Old 10-25-2022, 05:20 PM   #3
^ backwards. Standing in front of the vehicle looking into the engine bay, #1 is on your left, #4 on your right.
Old 10-31-2022, 04:29 PM   #4
ahmad_yaris
Drives: yaris 2007
I removed coil 3 and 4 from their cables and from the spark plugs. Then switch them, now coil 4 is in the slot 3 and connected to able 3, and coil 3 is slot 4 and on cable 4.
Its been 2 day error light went away, there is no more error code.
Old 10-31-2022, 06:01 PM   #5
Right now this is what I call a hiccup. Main reason why most times I get a code, I do nothing but clear it and wait to see if I get a reoccurring error. If yes, then I take action.
Old 10-31-2022, 06:47 PM   #6
bronsin
bronsin's Avatar
Hopefully it stays that way. But if it doesn’t, now you know which is number one and number four. And you can just do the switcheroo again if the error code sticks.
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
