Old 10-29-2022, 12:25 PM   #1
gkz
Power okay, but no cranking
A 2009 manual. Doesn't crank. Hear relays and fuel pump when key is turned. Once in awhile, if I wiggle the shifter, it'll crank and start. Push starts okay. Anyone see this before?
gkz is offline   Reply With Quote
Old 10-29-2022, 12:44 PM   #2
bronsin
bronsin's Avatar
It push starts and runs every time? Maybe it’s the “safety“ device that makes you push the clutch in before it will crank? It’s a switch on the clutch pedal up underneath the dash.
Old 10-29-2022, 01:29 PM   #3
gkz
Thanks; I'll check the switch.
Old 10-29-2022, 01:57 PM   #4
bronsin
bronsin's Avatar
I think you can defeat the switch by cutting the wire and placing it together. That way you won’t have to push the clutch in to start the engine. It’s an idiot “safety” feature that can go bad.
Old 10-30-2022, 12:19 PM   #5
gkz
I jumpered the connection to the switch to bypass it. I still get the same symptoms. Turn key, dash lights out, fuel pump runs, relays click; no starter. Any ideas?
Old 10-30-2022, 12:32 PM   #6
sh0rtlife
but if you wiggle the shifter it will sometimes start or always start?
Old 10-30-2022, 01:25 PM   #7
bronsin
bronsin's Avatar
What are the electrical connections to the transmission? Just the back up lights?
Old 10-30-2022, 02:49 PM   #8
gkz
Just sometimes, and I don't think there's any starter system related things with the manual, other than the clutch. I could be wrong.
Old 10-30-2022, 02:55 PM   #9
gkz
So, I checked the + solenoid terminal and had battery power. Disconnected the purple wire and got 12V when the key was turned (clutch depressed). Cleaned all terminals and treated w/dielectric grease. Same symptoms. Gave the solenoid a love tap with the hammer and it starts. Turned it off and still won't start unless I tap the solenoid. Looks like I need a new starter or just a solenoid if I can do that. Thanks everybody for your help.
Old 10-30-2022, 04:57 PM   #10
bronsin
bronsin's Avatar
Graduations! There’s nothing like fixing it yourself! $$$
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Installation of original power windows and locks in Yaris lantis DIY / Maintenance / Service 4 02-25-2012 01:38 PM
Power lock questions Taiyaki DIY / Maintenance / Service 22 04-22-2009 10:22 PM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
