Old 12-24-2022, 05:56 PM   #1
Max527
Unhappy Battery light on, then off....
Hi there.
2007 310,000km yaris.
Just today, after a blustery very cold day, the battery light has just started coming on, then off, then on, then off. The fm tuner I have connected oddly shows 11.5V-11.8 when the battery light comes on then goes away when the light turns off.
Would this be a battery issue? It stops after driving for 30 mins more or less.
Thanks for any help. Merry Christmas
Max527 is offline   Reply With Quote
Old 12-25-2022, 07:28 AM   #2
bronsin
bronsin's Avatar
Healthy battery voltage is at least 12 V, actually slightly more than That 12.5 really I’m afraid your battery is shot!
Merry Christmas and happy new year!
Old 12-25-2022, 07:31 AM   #3
bronsin
bronsin's Avatar
With the engine running and voltage measured it at the battery The reading should be more like 13 V definitely more than battery voltage measured without the alternator running. If this is the case it could be your alternator and the battery could be fine just not charged.
If you don’t know how to do this or don’t understand see your local mechanic. You wouldn’t want to buy a new battery for the alternator was really the problem!
Old 12-25-2022, 08:45 PM   #4
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Healthy battery and alternator should be 13-14v when running. Battery time, this bastard of a cold snap really takes a toll on old batteries.
My OG Toyota battery is approaching its ninth year of service and still cranks fine, knock on wood.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 12-27-2022, 12:47 AM   #5
IndestructibleYaris
LOL "battery time" what on earth....these people have no clue what they're talking about! The alternator puts out around 14v even with a dead battery in the tray and is engineered to run every accessory on the car and still remain at a charging voltage above 12.8v. Read the service manual or the alternator rebuild guide in the search function. Good luck
IndestructibleYaris is offline   Reply With Quote
Old 12-28-2022, 09:40 AM   #6
Voltage regulator inside the alternator is starting to fail.
I can also say with absolute certainty that your brushes are pretty much at end-of-life.
Old 12-28-2022, 03:52 PM   #7
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Not everybody is all-knowing as you, Your Highness.
2014 NCP131 5 Speed
Old 12-28-2022, 05:52 PM   #8
Compeer
Drives: NCP90 TRD Yaris Manual
By "battery time" he meant the cold snaps during the year are when the most batteries fail and are sold. Maybe hes not the only one who needs a clue?
A rebuilt/rebuilding the alternator should be pretty cheap. We used to sell refurbished units for under $100usd for a common car like this. A decent sparky will have a stack of them ready to exchange with you or will take an hour to rebuild yours.
Check anc clean all your earth connections when you replace the alternator, Clean the terminal end on the alternator, battery and any other earth leads going to the engine (unbolt them clean corrosion off with light sand paper and reinstall). Bad earth connections cause the voltage reg to run hotter and eventually burn itself out and you dont want a repeat.
When ever you have charging problems you should always check all the electrical connections and clean them, This is always the first step in diagnosing a charging fault.
Compeer is offline   Reply With Quote
Old 12-28-2022, 06:29 PM   #9
In the North American market, 2006-2008 have a known design flaw with the voltage regulator. He is showing the exact early warning signs that the regulator is failing. Frankly I'm surprised he's gone this long without symptoms presenting themselves.
Old 12-28-2022, 06:50 PM   #10
BLH
Drives: 2007 Yaris Sedan
Technical Service Bulletin EL002-07
The one I saw. Was corrosion on the regulator connections inside the alternator. Made things like the warning light to turn on.
Old 12-28-2022, 07:29 PM   #11
Compeer
Could be as simple as a loose/frayed battery terminal. Always worth starting simple first and if it is the reg the terminals are all nice and clean to help them eliminate a future issue.
Old 12-28-2022, 07:48 PM   #12
Could be as simple. Highly doubt it. I've lived it, been here long enough to see countless others through it. It'll trace back to the regulator.
Old 01-01-2023, 05:55 PM   #13
RedRide
RedRide's Avatar
FWIW.....
The cold can reduce cold cranking power.
However, it is actually extreme heat that can kill it quicker than cold
Old 01-08-2023, 08:02 AM   #14
Max527
Car eventually died then revived itself in time for me to get home. Changed alternator and all is well. Thanks
Old 01-08-2023, 08:07 AM   #15
bronsin
bronsin's Avatar
Check engine light + vibration Lisbeth DIY / Maintenance / Service 12 04-05-2020 09:28 PM
Battery keeps going dead Outdoorsman In Car Entertainment + Electronics (audio / video / alarm) 6 09-09-2013 04:43 PM
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 07:21 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
