#1 |
![]() Drives: 2007 Yaris Sedan Join Date: Aug 2022
Transmission issues after 1nzfet swap
Hello I recently completed my first project engine swap and have my second gen sedan rolling but my issue now is my transmission, code p0500 I swapped out the sensor(s) and no luck. So the story to it is I kept the JDM transmission that came with the motor since almost all of the connections and sensors matched the US transmission, the only problem was the JDM transmission had a port cover where the speed sensor is located I removed it and installed the transmission speed sensor from the US transmission and now my car will not shift past 3rd gear. I was eventually going to swap to a manual transmission but for transportation reasons I needed to drive is sooner than expected. Anyway any help would be greatly appreciated thank you! Oh it’s an automatic transmission just in case you didn’t catch that. 😎🤙
#2 | |
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
#3 |
Drives: scion xb Join Date: Dec 2022
found some interesting info on using the jdm u340e in usdm cars.
The wiring for the solenoids is a little different. https://www.drive2.ru/l/561243512448747398/ Accord to this, the easiest option would be to add a wire into the vehicle side of the harness (pin#7)and run it to ground. This will allow the lockup solenoid to operate. |
| Transmission swap 05 Echo | suprf1y | Performance Modifications | 18 | 03-30-2019 09:00 AM |
| 06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) | 06YarisRS | Performance Modifications | 448 | 12-06-2018 08:12 PM |
| TPMS Issues After Wheel Swap | pulsar2121 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 07-07-2015 05:38 PM |
| transmission swap | kralmrax | DIY / Maintenance / Service | 5 | 07-22-2006 01:04 PM |
