Old 12-28-2022, 04:48 PM   #1
mallu86
Drives: Toyota Yaris Mk3 - 2012 1.33 T
Yaris MK3 Heater control lights
Hi, Just bought a Yaris mk3 2012
Just wondering what the process is for fixing the lights for the heater controls.
Are they bulbs or LEDs? and are there any online videos of a breakdown/tutorial thanks!
The image is attached below!
mallu86 is offline   Reply With Quote
Old 12-28-2022, 05:43 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
I recently had to replace one of mine and they were T4 NEO wedge bulbs with little orange bulb covers on them. Its quite easy to do but AFAIK there is no dedicated guide.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 12-29-2022, 12:19 AM   #3
sh0rtlife
depending on your dash depends on what covers they have..DO NOT expect to be able to "re-use" the old covers as they tend to rip
remove the panel and look at the back of the units and youll see a lil grey? round plug with a flat head notch in it..give that a 1/4 turn and then they just fall out... pull the bulb from this plug/holder.....its that simple
mines got the blueish dash so my units have blue/green covers
Old 12-29-2022, 11:57 AM   #4
mallu86
any links for the bulbs mate? Thanks
Old 12-29-2022, 04:47 PM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
I bought a set of amber T4 NEO LEDs off ebay for like 10 bucks shipped.
Yeah the gen 3s use orange covers(I call them bulb condoms ). I was actually surprised to see them still use incandescent bulbs, everything else on the 3rd gens has LED backlighting.
2014 NCP131 5 Speed
Old 12-30-2022, 02:48 PM   #6
sh0rtlife
best i can tell since they use that same "dial and knob" configureation on a bunch of cars scion included..they just stuck with it cause it worked....tho in my switchover to the knurled rings from a scion i discovered that atleast 1 revision of the housing happened that made the rings not interchangeable with "early" housings needing the entire later houseing..and its a super minor change in how the ring mounts and how the stop points "feel" when dialing but are otherwise unchanged
2009 Toyota Yaris OEM Cruise Control DIY BentSpace DIY / Maintenance / Service 7 04-16-2014 09:05 PM
