Old 12-29-2022, 07:22 PM   #1
twoninety
Drives: yaris 08
keeping it cool
hey everyone !,
im new to this place.. :)
here it goes...
i have a 08 yaris with 290,000km (180,000 mi)
today i was doing some cleaning and noticed the overflow coolant reservoir was almost empty. keep an eye on things under the hood and usually reservoir level looks good
hmmm ?
so i filled reservoir to the max mark ( premixed pink/ toyota) coolant, and went for a drive
kinda cold here in toronto, around 3c (40f) but eventually , while the car was in my outdoor garage, coolant temp rose to around 95c (203f) ( obd data), then the fan kicked in.
also, to the touch, the top hose to the rad was quite warm, but the bottom hose was much cooler
eventually, the bottom hose got quite a bit warmer ( thermostat opened ), when coolant temp went over, approx, 90c ( 194f)
fluid in reservoir stayed at same level as before- at the max mark
went for as drive, and coolant temps came down to around 80c (175f) after a few minutes at low speed driving
hmmm
i did notice some steam , that appeared to be coming from the inside top of the rad, just kinda under the top rad hose
a rad leak maybe ?
chemical sealant solution?
or ?
given all the above observations/ info, any thoughts on whats going on.. why reservoir was previously empty?
*** dip stick and under oil cap looked fine, clean oil. and removing rad cap ( when cold/ cooler) fluid looked okay. tried to add some coolant but only took a couple of ounces before overflowing...
power/ driveability is good/ normal..
any thoughts/ ideas as to whats going on?
much appreciated :)
twoninety is offline   Reply With Quote
Cool race video. Palmer812 Photo-Video-Media Gallery 4 03-23-2010 09:08 AM
New Yaris Owner Wondering: Cool Engine Indicator: Normal? msmitka New YARIS Purchase Forum 27 12-17-2009 08:10 PM
Goodwood Revival - pretty cool old engines! tomato Off-topic / Other Cars / Everything else Discussions 13 09-02-2009 02:35 AM
Can i drive when the COOL indicator light is on? hans_fh General Yaris / Vitz Discussion 22 11-07-2006 10:05 PM
Top 10 Cheap Cool Cars for Teens for 2006 hhcchen Off-topic / Other Cars / Everything else Discussions 21 06-04-2006 05:36 PM
