Old 12-30-2022, 04:53 PM   #1
komichal
2SZ-FE - belt change
Hi All,
I do not want to spoil other topic with related question so let me ask in a separate one.
Do I need to replace the drive belt?
If I can see the service intervals well, the belt needs "inspection" after 60,000 miles/72 Months and then "inspection" every 15,000 miles/18 Months. So no replacement mentioned anywhere.
Mine has 130,000 miles and 15 years of service and still no problem (no squeaking, never had to adjust the tension or anything).
Shall I ask the shop to change it for me (as preventive maintenance) or is it simple enough to be changed in the driveway by myself? Or are Toyota belts magical enough so that I do not need to worry about changing it yet?
Thanks in advance for any comment.
New TSB - 2006-2015 Yaris Drive Belt Squeal Noise on Cold Start CTScott DIY / Maintenance / Service 12 03-24-2015 06:19 PM
Drive Belt Replacement wagon DIY / Maintenance / Service 2 12-28-2014 11:24 AM
Accessory Belt change. When?? mhkritzinger DIY / Maintenance / Service 12 10-23-2009 02:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
