Old 01-06-2023, 06:00 PM   #1
mallu86
Drives: Toyota Yaris Mk3 - 2012 1.33 T
Toyota Yaris MK3 break holder faulty
Hi, Just wondering where I can get the rear brake bulb holder for a Toyota Yaris 2012 - or if anyone knows the part name that will help a lot thanks!
I have attached the image of the bulb holder below it states Molex B3 but when I do a google search there are no direct links etc...
for a bit of context, the rear bulbs don't work sometimes, when I move the wires around it seems to start working so it seems like they either have a loose connection or have faulty wires.
Thanks!
mallu86 is offline   Reply With Quote
Old 01-06-2023, 06:27 PM   #2
sh0rtlife
remove the tail light so you have access to the socket, at this point you will be able to see a couple of tabs..which likely simply need cleaned and "tweaked" to make a better contact...more often than not on just about any car ever made this is the issue
Old 01-06-2023, 07:13 PM   #3
mallu86
Thanks, ill have a go tomorrow
Toyota ending Yaris Hatch & Sedan production for United States by end of June ferio252 Third Gen Yaris General Discussion 18 07-13-2020 01:05 PM
