Old 01-11-2023, 05:01 AM   #1
sdotmurray
Drives: 2008 Yaris automatic
2008 auto transmission drain plug.
Does anyone know what the metric thread callout numbers are on the automatic transmission drain plug for the 08 Yaris? I was thinking of changing it with a magnetic drain plug but I can't find this info online anywhere.
Thanks!
sdotmurray is offline   Reply With Quote
Old 01-11-2023, 11:52 AM   #2
bronsin
bronsin's Avatar
I wouldn’t worry about that. Just drop the pan, change the filter,. You should measure the oil that drains out, and replace it with exactly the same volume of the new fluid.
Old 01-11-2023, 12:29 PM   #3
sh0rtlife
in reality a mag plug isnt all that beneficial in an auto....the filter gobbles up just about everything and anything metallic wont go thru the filter anyway
Old 01-11-2023, 07:25 PM   #4
ex-x-fire
Buy a couple of those strong magnets from Harbor Freight and stick them on the outside of the pan.
Old 01-12-2023, 04:13 AM   #5
bronsin
bronsin's Avatar
Good idea except I think the oil pan is too round. I don’t think there’s any place flat. I have use those magnets and they are really amazing!
Old 01-12-2023, 04:16 AM   #6
bronsin
bronsin's Avatar
Actually I would have to believe the drain plug is magnetic that’s already in there.
Old 01-21-2023, 09:24 PM   #7
bairjo
The ATF pan on my 2010 already has two magnets in it. I imagine it is the same for the 08. Also the filter is more like a screen. I replaced my filter at the time, but i won't waste my money on that again.
Old 01-22-2023, 12:03 AM   #8
Billiam
Drives: '10 White Yaris 4D LB
No need for additional magnets. There are already 2 in the pan.
If you want to enjoy your car, stay off of the internet.
Old 01-22-2023, 04:36 PM   #9
bronsin
bronsin's Avatar
If you have the money and get a charge out of that kind of thing Why not change the trans oil and filter?
Is it really necessary? Probably not. Have I ever done it? No!
Now manual transmission oil I change that every 30,000 miles. Usually just like two or 3 quarts of that stuff. Automatic transmission oil there’s usually something like 8 quarts.
Old 01-24-2023, 12:54 PM   #10
bairjo
You pretty much answered your own question Bronsin. I don't get a charge out of doing repairs on my car. Plus a new OEM filter on Amazon is $64. I'll just keep doing a double drain and refills every 35,000 Miles. I'm at 215,000 and the thing runs great.
For what it's worth, I did not change the ATF the first time until around 140,000 miles when I noticed some rough shifting during acceleration on the freeway. Changing the fluid and filter took care of that.....Amazing.
Old 01-26-2023, 05:42 AM   #11
Billiam
BTW, the drain plug is not magnetic
About to replace the transmission fluid on an automatic 2008 yaris with 172kms jessesYaris General Yaris / Vitz Discussion 6 09-23-2021 04:51 PM
Yaris 2007 sedan (auto) Transmission fluid change and rear wheel noise DevilzMafia DIY / Maintenance / Service 8 12-24-2012 08:05 AM
Auto Transmission removal artichap DIY / Maintenance / Service 14 10-23-2012 10:27 PM
automatic trans drain plug eddy DIY / Maintenance / Service 3 02-14-2011 11:59 PM
my 2008 yaris needs a new transmission kcanuck General Yaris / Vitz Discussion 4 05-17-2010 11:27 PM
