Old 01-12-2023, 05:04 PM   #1
sh0rtlife
airbag code B1801
my obdlink had a firmware update and can now scan srs codes on the yaris WOOT,
B1801 "open in D squib circuit"....someone care to translate?
i had a rough couple days, so forgive my lack of searching , and also destroyed another crank position sensor lastnight.....seems to be high rpm that kills em..as i was WOT and angry
Old 01-15-2023, 03:05 AM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
this is for steering wheel Airbag. Apparently this is common, lucky you found that as your steering wheel airbag is currently out of commision.
Here is a vid on it, Normally you just replace the cable but it can be the clock spring too. https://www.youtube.com/watch?v=0tV4qs1Rf6w
Compeer is offline   Reply With Quote
Old 01-15-2023, 06:07 AM   #3
BLH
Drives: 2007 Yaris Sedan
On my 2007.
The Clock Spring was in a recall and one of the issues fixed at no cost to me.
Old 01-15-2023, 01:55 PM   #4
sh0rtlife
huh this actualy pleases me knowing its non functional
guess i should pop into it and check n see whats up, i know the recall work was never done, but i also dont want the dealer touching shit lol
Old 01-15-2023, 03:04 PM   #5
How'd it pass safety with outstanding recalls?
Old 01-15-2023, 05:52 PM   #6
Compeer
You can search on toyota to see if your car needs recall work done. https://www.toyota.co.nz/owners/recall/
Old 01-15-2023, 08:55 PM   #7
sh0rtlife
yeah we dont have that here, 2 concerns when importing it from canada to the US, both were emissions related, 1 was simply an obd2 test the other was a certified letter from toyota stating it complied with US federal emissions and safety standards
Old 01-15-2023, 08:57 PM   #8
sh0rtlife
oh i know for FACT it does..wifes owned it since NEW....after the warrenty was up a dealer hasnt touched it since
which..if memory serves means clock spring, and both air bags right or was there more?...i know the seat rail issue was taken care of but was the last of the things done durring warranty
honestly if i could get a dealer to hand me the parts so i could do it myself it would have been done allready....i just have issues letting the stealership touch it
Old 01-15-2023, 09:22 PM   #9
Compeer
No it depends on if your car had the defective batch parts installed or not, my car did not so never had a recall.
Old 01-15-2023, 09:23 PM   #10
During the height of the Takata fiasco, very little, if any, complaints about dealer work for either of the bag recalls.
Old 01-17-2023, 12:29 PM   #11
CrimsonEclipse
Drives: .
On the bright side, the clock spring is a relatively easy and inexpensive replacement.
CrimsonEclipse is offline   Reply With Quote
Airbag - can't clear code 32 after rough passenger ehud42 DIY / Maintenance / Service 1 11-05-2019 03:03 PM
2007 Yaris airbag light won't reset code 52 jmandawg DIY / Maintenance / Service 2 06-24-2019 11:42 AM
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 08:03 AM
Airbag ECU code 31 - what does it really mean? ajuniper DIY / Maintenance / Service 6 11-30-2014 09:05 AM
full tank japle Fuel Economy Forum 15 12-10-2013 11:05 AM
