Old 01-16-2023, 04:44 AM   #1
bronsin
bronsin's Avatar
Tight spot in rack and pinion
Tight spot in rack and pinion. I was driving a used Lexus for a friend to evaluate and win going down the highway and right in the center of the steering there’s a tight spot. A tight spot in the rack.
What could this be? Otherwise everything was fine.
Thanks!
Old 01-16-2023, 09:34 PM   #2
sh0rtlife
2 things come to mind..was it noticeable at ALL rpms?..some cars will get stiffer at higher rpms and loose at low
is it drive by wire or hyd/elec?
double check that it doesnt do it in other spots..find an empty parkinglot.....if it does it in other spots ts a bad bearing in the column
Old 01-17-2023, 02:38 AM   #3
bronsin
bronsin's Avatar
It’s a 2011 so I would assume it’s hydraulic. I noticed it cruising at 60 On the highway. It doesn’t do it driving around town or in the parking lot
Old 01-17-2023, 11:31 AM   #4
sh0rtlife
its likely to be intentional then...alot of cars after mid 90s especialy higher end stuff had a setup where the higher the speed the stiffer the steering in an attempt to keep ppl from losing control it also dampens alot of rut issues that alot of drivers will complain about not realising they need to pick a different line
all said its likely normal
Old 01-17-2023, 12:49 PM   #5
bronsin
bronsin's Avatar
OK thanks!
Rack and Pinion Rebuild Tool IndestructibleYaris DIY / Maintenance / Service 10 11-10-2022 01:17 AM
Rack and pinion replace or rebuild bearwin DIY / Maintenance / Service 3 11-20-2015 12:40 AM
