Old 01-28-2023, 07:09 AM   #1
vidfan
Drives: 08 yaris
Rubbing noise after installing drum brake
Hello, I have a 2008 Sedan and recently had my brakes replaced. The drum brake on the rear passenger tire rubs the inside of the wheel cap when I drive for 5-10 minutes. I've had my mechanic brother look at it and he has tried to adjust the brake to make it set closer to the bearing, shave the side of the drum brake that was rubbing, and replaced the bearing altogether but it still rubs.
Has anyone had this issue before and maybe had a solution not already tried?
Thanks!
vidfan is offline   Reply With Quote
Old 01-28-2023, 11:51 AM   #2
sh0rtlife
sounds like a wrong shoe or wrongly installed shoe
Old 01-28-2023, 07:39 PM   #3
ex-x-fire
I'm not getting it, is the drum rubbing the backing plate?
Old 01-28-2023, 08:32 PM   #4
Compeer
Drives: NCP90 TRD Yaris Manual
Wheel is rubbing on the hub? Can you please make a video to show us?
Compeer is offline   Reply With Quote
Old 01-28-2023, 08:55 PM   #5
sh0rtlife
thats another couple thoughts, wrong drum, bad bearing
Old 01-28-2023, 09:14 PM   #6
I'm lost as to what 'wheel cap' is.
Drum Brake Issues Thirty-Nine DIY / Maintenance / Service 10 03-31-2022 11:48 PM
Which brake drum brand should I buy? Rob888 DIY / Maintenance / Service 7 10-25-2021 05:17 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Drum brake problem. theb DIY / Maintenance / Service 4 04-23-2014 02:04 AM
