Old 04-02-2023, 12:47 AM   #1
james2007yaris
Drives: 2007 Yaris
Eiback Pro Kit Springs: Correct P/N for 07 Hatchback US Model
What Eibach Pro kit lowering spring kit P/N is correct for this application:
2007 Yaris
US Model
1.5L 1NZ-FE Engine
Hatchback
XP90 Style per Wikipedia:
https://en.m.wikipedia.org/wiki/Toyota_Yaris
--> There seems to be 2 options fron 'Tunershop Worldwide on eBay.
E10-82-092-01-22
https://www.ebay.ca/itm/394289310143...emis&media=SMS
They also recommend H&R 30 mm springs:
https://www.ebay.ca/itm/284522802077
Tunershop-Worldwide on eBay doesn't recommend the '02-22' kit .They recommend 01-22 but it says it's for DAIHATSU Charade.
They communications with them are choppy and they can't provide any other information Communication hiccups.)
Questions:
1. What Eibach kit is correct for this Yaris?
2. What are the differences in the 2 P/Ns?
3. Are the H&R springs more Bouncy and how do they really rate to Eibach Pro Kit?
4. Has anyone regretted the Pro Kit for the daily Driver and wish they got sportlines?
james2007yaris is offline   Reply With Quote
Old 04-02-2023, 12:01 PM   #2
sh0rtlife
"springs" are not what makes a ride "bouncy", damping force of a shock/strut does...however too stiff a spring will make it ride HARD
Old 04-04-2023, 03:45 PM   #3
james2007yaris
Drives: 2007 Yaris
I just bought my second Yaris in the previous owner cut the OEM springs and it is definitely bouncy. The springs are definitely the culprit because the shocks can't keep up with the increased spring rate.
Any idea on my original question?
Old 04-04-2023, 04:17 PM   #4
In Canada, when you purchased your Yaris with lowering spring option, Eibach Pro Kit is what you actually got. Lowers 1 inch (25mm) front and rear.
If your car is currently "bouncy", it's not because of cut spring. Your dampeners are worn out.
I think the difference between the two pro kits are the amount of drop. One is same drop front/rear and the other has more drop in the front than the rear.
Old 04-04-2023, 09:51 PM   #5
sh0rtlife
damping force is what cleans up and removes the "bounce" ..short of having 1 ton truck springs the bounce is always in the shock
pro kit lowering springs
HELP: Toyota yaris 2010 model 5/D Hatchback BODY KIT DIMAGUIBA General Yaris / Vitz Discussion 0 02-16-2014 01:39 AM
[WTS] Brand New Sport Rims 1151127 Items for Sale by private party 20 03-22-2013 12:28 AM
FS: Eibach Pro Kit springs Yarflana Items for Sale by private party 1 03-15-2013 07:41 PM
Most Reliable Makes of 2010 2007yariz General Yaris / Vitz Discussion 16 12-02-2010 04:37 PM
eibach pro kit vs trd springs intake Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 08-22-2007 03:24 PM
