Old 04-15-2023, 09:04 AM   #1
jargey3000
Drives: 2015 yaris le
HELP pleae:Will Honda Fit tires fit my Yaris?
I get confused with the tire/ wheel specs , tolerances etc. Can someone help?
Will the wheels off a 2013 Honda Fit fit my 2015 Yaris, 4-dr LE? (Canada) would appreciate some guidance, thanks.
jargey3000 is offline   Reply With Quote
Old 04-15-2023, 09:36 AM   #2
bronsin
bronsin's Avatar
I don’t know. But you might ask Siri.
Old 04-15-2023, 02:43 PM   #3
sh0rtlife
asking 3 times wont get you an answer faster....
the short answer is yes....the long answer is..well..without trying you wont know for sure..and that has mostly to do with offset and caliper clearance
yaris
4x100 lug pattern, 54.1 center bore, 37-53 in offset depending on how it was ordered
fit
4x100 lug, 56.1 bore(youll want hub centric rings to take up the slack), 48-52 offset
https://www.wheel-size.com/size/honda/fit/2013/
https://www.wheel-size.com/size/toyota/yaris/2013/
Old 03-29-2024, 09:12 PM   #4
IndestructibleYaris
Miata rims or old civic rims 14 inch cheap and readily available. Alloys 6 for 100
IndestructibleYaris is offline   Reply With Quote
First impression - Hankook Ventus S1 Evo DiCaprio Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-22-2020 09:51 PM
Will these tires fit my 2009 Yaris? birdbrainxzx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-16-2020 08:20 AM
Test drove Rio5, Fit, and Yaris all today kmf123kmf New YARIS Purchase Forum 16 10-02-2009 07:48 PM
