Old 05-20-2023, 04:14 PM   #1
yaris2014toyota
Drives: Yaris 2014 2-Door LE
ABS suddenly stopped working in my Yaris 2014 LE Liftback
ABS suddenly stopped working.
I looked up the related fuses from:
https://www.autogenius.info/toyota-y...e-box-diagram/
Then I checked my fuses and they looked okay.
What should my next steps be?
- I can replaces the fuses regardless.
- What else?
Thank you in advance.
yaris2014toyota is offline   Reply With Quote
Old 05-20-2023, 07:00 PM   #2
bronsin
bronsin's Avatar
Is the check engine light on? Even if it isn’t, I suggest putting a code reader on the ABS 2 port. If you don’t have a reader, you can go to AutoZone or similar, and they will read the codes for you, if there are any.
Don’t worry about driving your car. ABS has not been statistically significant in reducing accidents. As long as nothing is wrong with the brakes themselves, you should be fine. they are components that can fail on the ABS systems on older vehicles that would be prohibitively expensive to repair or replace. It’s very common on older vehicles when ABS fails to just do without it
Old 05-22-2023, 02:25 PM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
ABS Wheel speed sensor maybe? Hook up a code reader too it that is capable of pulling ABS codes and take a look.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
abs, fuse
2014 yaris bought at hertz jstert Third Gen Yaris General Discussion 9 05-21-2016 06:13 PM
2014 Yaris or 2014 Corolla yarisse54 Third Gen Yaris General Discussion 7 06-06-2013 12:44 AM
