Old 06-12-2023, 05:45 AM   #1
ZombiePunkRat
Drives: 2005 Yaris
Exclamation Intermittent fault with starting
I have a 2005 hatch, and I've been having intermittent problems with starting. Sometimes it wont start first go and struggle to turn over, even though it really tries. There used to be a pattern to it but now It's just random.
There is also error codes coming up for the camshaft position sensor, VVT oil control solenoid, and a third sensor on the underside of the engine which I've forgotten the name of at the moment, but there's also no pattern to it and they'll just pop up, most of the time without an engine light.
Has anyone had this issue or something similar?
ZombiePunkRat is offline   Reply With Quote
Old 06-12-2023, 04:42 PM   #2
sh0rtlife
how old is the battery?..a bad battery can cause the starting issue and in turn the low voltage and slow rotation can cause those codes....
My Yaris has an intermittent fault Yarisprobs General Yaris / Vitz Discussion 4 01-17-2018 07:12 AM
Yaris intermittent starting problem sujay68@gmail.com General Yaris / Vitz Discussion 0 12-08-2017 09:10 AM
intermittent hard starting Ramon1691 DIY / Maintenance / Service 17 07-20-2016 01:49 AM
Intermittent electrical fault - battery drain Half_Baked DIY / Maintenance / Service 1 05-20-2015 07:02 PM
NEED ENGINE CHECK LIGHT CODE LIST Attitude Forced Induction Forum 12 04-11-2011 07:38 PM
