Old 06-24-2023, 11:27 AM   #1
CT_11_Blue_HB
Drives: 2011 Yaris 5dr HB Auto
Echo Cooling Fan Wiring Diagram
Trying to trouble shoot a non-functioning cooling fan on 2002 Echo with 330K miles. I found a wire to the fan connector was chewed through and replaced that. I have confirmed fan works by connecting directly to battery. Have also checked fuses (one in engine bay) and two relays in engine bay, as well as disconnected temp swtich at bottom of radiatior (read that this will turn on fan). Turning on AC does not turn on fan as it should.
Also pulled one of the fan relays and shorted swtiched side in the engine compartment fuse box. Still no fan. Suggests to me something between fuse box and fan.
Any ideas? Thinking a wiring diagram might be useful, but can't find one.
Getting ready to pull fuse box from engine compartment and look for broken or shorted wires.
Thanks!
CT_11_Blue_HB is offline   Reply With Quote
Yaris / Echo sedan 1SZ-fe 1.0 L cooling fan trigger at high temperature Asadeng DIY / Maintenance / Service 4 08-31-2022 01:14 AM
Cooling Fan Not Running silverswitch DIY / Maintenance / Service 15 03-08-2021 02:05 AM
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
Cooling fan not working??Will my machine blow?? vickgeo1981 DIY / Maintenance / Service 2 06-30-2015 06:39 AM
'02 Echo cooling fan potential problem tmontague DIY / Maintenance / Service 2 04-07-2015 10:06 AM
