Old 07-07-2023, 11:28 AM   #1
alanwagen
Corroded Postive battery terminal
On a 2015 Yaris, the positive battery terminal has almost failed due to a massive build up of corrosion. I got a new terminal and will also replace the battery as I think it was leaking at the positive terminal.
My concern is the nut holding the wire to the terminal may be very difficult to remove. I have a mini-hack saw to cut the nut.
Any tips or tricks to do this easier? Thank you.
Old 07-07-2023, 07:15 PM   #2
ex-x-fire
Tap a 6-point socket on to it, it should come loose.
Old 07-09-2023, 01:42 AM   #3
bronsin
bronsin's Avatar
Coat the terminals should be coded with a thick layer of wheel bearing grease. The corrosion will prevent corrosion. Should the battery case leak leak
Old 07-09-2023, 09:33 PM   #4
alanwagen
I got it changed, it was very corroded. It didn't want to budge and it broke in half.
We also got a new battery at Costco which they provided a size 35 which was too tall and we had to go back and get a H5 which did.
Old 11-03-2023, 12:01 AM   #5
comk4ver
Drives: '08 Yaris
Weird Octagonal Nut
You too? How did the battery strap handle that? Is there a chance that you could take a picture of the fusible link? It's under the positive battery cover. Was there anything under that octagonal nut that broke?
comk4ver is offline   Reply With Quote
Battery Relocation DIY tmontague Performance Modifications 7 03-23-2019 08:11 PM
We Have the Beats! ern-diz Photo-Video-Media Gallery 41 05-15-2018 05:58 AM
Positive Battery Terminal alex33016 DIY / Maintenance / Service 5 02-08-2015 02:17 PM
Battery terminal _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 2 03-18-2010 11:48 AM
