Old 07-08-2023, 08:35 PM   #1
kou
Drives: 08 lb
Turbo Yaris for sale.
Turbo Yaris with built motor and LSD plus a bunch of extra new and old parts collected over the years. Runs no smoke but needs some work. priced to sell. Will make a list of what it's got if there is any interest. $2500
Parts on car.
Modified Zage turbo kit.
Trd short shifter.
Twm short shifter.
Trd springs.
Trd sway bar.
Tokico hts struts and shocks.
Cusco strut brace.
Cusco subframe brace.
Bell works steering hub and momo wheel.
Motor has Brian crower pistons and Molnar rods.
Trd limited sli differential.
Corbeau gts driver's seat and a corbeau bucket seat in passenger seat.
Autometer gauges.
Aem fic with boomslang harness.
Aem fuel pump.
550cc injectors.
Golden eagle fuel rail.
Blower work fuel pressure regulator.
Yaris s front lip and side skirts.
Extra new stuff to put on full stainless brake and clutch line. Sway bar bushings. White line control arm bushings. outer tie rod ends. New Teflon fuel line and fittings. Light weight pulleys and a bunch of other stuff.
Old 07-10-2023, 06:11 PM   #2
Ssp
Drives: 12 yaris
What are the issues with the car? This is 91mustang, lost my access to my password reset.
Ssp is offline   Reply With Quote
Old 07-10-2023, 07:20 PM   #3
kou
Drives: 08 lb
Needs a little exhaust work and the clutch is starting to go.
Old 07-11-2023, 12:48 PM   #4
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
That's way too cheap!
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 07-11-2023, 06:35 PM   #5
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
damn I would take that project on for sure if I had the cash
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-15-2023, 04:33 PM   #6
theinteriorautomechanic
Drives: Slowcart
Still available?
theinteriorautomechanic is offline   Reply With Quote
Old 07-16-2023, 07:35 PM   #7
kou
Drives: 08 lb
Yes still available.
Old 07-23-2023, 12:35 AM   #8
Drives: Slowcart
Can you send me more details as to what it needs and more pictures?
Old 07-26-2023, 10:30 PM   #9
Drives: Slowcart
Old 08-27-2023, 09:06 AM   #10
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Hi Kou. Is the car still available? Thanks
Old 08-27-2023, 09:12 PM   #11
Drives: Slowcart
Still waiting on a message or reply
08 Yaris 'S' Turbo Build scarsofcarma Forced Induction Forum 22 10-04-2020 03:23 PM
Yaris Firesale - Entire Car, Turbo Kit, Body Kit +++ Ohio fnkngrv Cars for Sale by private party 0 08-12-2013 10:41 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
