Old 07-21-2023, 01:09 PM   #1
komichal
Fuel leak close to the tank
Hi folks,
I felt a strong fuel smell inside the car so I inspected the fuel system and found ruptured hose close to the fuel tank. Took two pictures. Originally the hose was ruptured in the red circle. I cut the ruptured part and assembled it back but used a bit more power than I should and now the gas is leaking in the yellow circle.
I know that everything there is rusty af so it was only a matter of time. But I am supposed to drive 500 km over the next two days and cannot get it fixed properly now. I suppose that this ruptured hose is only between the tank and charcoal canister (that black box is charcoal canister I guess) and I do not have to worry about losing all fuel if that rusty pipe with the formerly ruptured hose falls off completely. Please, am i right?
Fixing this does not look to me as a simple diy, at least I was not able to find that metal pipe new, anywhere.
Thanks folks for any comment on this.
Car runs better with full fuel tank komichal DIY / Maintenance / Service 1 12-11-2022 12:18 PM
Fuel pump, sender, seal, wiring, and cluster mavrick DIY / Maintenance / Service 5 07-22-2019 05:34 PM
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
fuel tank hatch cover yaris9876 DIY / Maintenance / Service 5 01-14-2013 10:03 PM
