#1 |
![]() Drives: 2016 Toyota Yaris Join Date: Jan 2023
Install of Amazon Fog Lights/ DNA MOTORING/ FL-ZTL-171-AM
Did 2 weeks of Google research on installing on my 2016 Toyota Yaris. Used the existing OEM plugs that were taped up. Tried and not working. Unscrewed bottom portion of Steering Panel, 3x screws. Looked for the Brown and Green wires in the Turn Signal stalk. Soldered them together and plugged in. Bam, works everytime I turn on the Full Headlights! Even the 'fog light symbol' turns on in the dashboard. The 2x screws were not enough to secure to the bezel/bumper, so I added 1x Self Tapping screw, thru the bracket holding side, kinda 'catching some bumper plastic and the fog lights bracket.
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Cutting factory harnesses makes me cringe bigtime, I just grabbed a fog light stalk out of a 2010 Tundra and swapped it in, no cutting required.
Also why are you running H16 bulbs? The factory specified size for the Yaris should be H11.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
#3 |
Many of us on here have cut into our stalk wires, or any other areas with no issues. The H16 bulbs offer a Amber color, that's why I used those..btw, Many of us here don't care w/ the manufacturer requires, we do what mechanically works in our ability.
#4 |
BTW, guys, I did not even use a Single wire/harness/switch from the kit. They Yaris already had everything pre-installed, just not hooked or connected/soldered.
#5 | |
Gen 3 > Gen 2
| DIY yaris III fog lights installation | karloslatynos | Third Gen Yaris General Discussion | 53 | 11-12-2017 04:03 PM |
| Fog lights and shift knobs | flip_yaris | Cosmetic Modifications (Exterior/Interior) | 3 | 10-20-2008 06:36 AM |
| Fog lights and shift knobs | flip_yaris | Cosmetic Modifications (Exterior/Interior) | 4 | 09-26-2006 11:48 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 02:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-03-2006 12:38 AM |
