Old 08-18-2023, 02:39 PM   #1
password
Drives: 2009 yaris
2009 starter motor grounding ?
Is there suposed to be a ground strap on the starter bolts ?
How about lock washers?
I'm about to add both........... not sure if the old ones rotted off or what........ but my starter isnt grounded. ( wont start unless I add ground )
password is offline   Reply With Quote
Old 08-18-2023, 04:09 PM   #2
remcafee
the starter nut has a washer built into it, aftermarket ones you would probably need to add one
Old 08-20-2023, 12:30 AM   #3
xdarkxfirex
Drives: 2015 yaris le
Starter could've been replaced at one point and it was too loose and fell off over time
xdarkxfirex is offline   Reply With Quote
Old 08-20-2023, 09:15 AM   #4
password
Drives: 2009 yaris
hats what I am assuming. and that is why I am asking the question.
So the question is......... are there saposed to be lock washers? is there saposed to be a ground strap ?
Starter Problems - Heads Up tmontague DIY / Maintenance / Service 6 03-01-2019 10:04 AM
