Old 09-10-2023, 07:41 PM   #1
haydenjowell
Drives: 07 Yaris Sedan
2007 Yaris Sedan: No start or click, green temp light flashing
Need some help! I can't figure out what is going here. I have a 2007 Sedan that was operating just fine. Went to a doctor's appt, came out to leave and didn't start. No cranking, no clicking... nothing.
Also, when I attempt to start it. The green temperature/coolant light starts flashing. I don't think I've ever seen it do that before (even when the car didn't start). The light will remain flashing even after I move the key to the off position and remove it. Only was I can get it to stop flashing is to shift into a R/N/orD and then back to park.
Which I should mention.. the steering wheel isn't locking when the key is out and I can work the shifter (Automatic).
All electronics in the car work perfectly fine. Battery is fully charged. Starter was replaced about 3 months ago... Thermostat was replaced near the same time. Car had been overheating, but the problem was fixed.
Thinking the green temperature light flashing might mean low coolant level [preventing the car from starting], I checked the coolant. It is full.
Checked all the fuses under the hood, nothing is blown.
There's 12.5 volts at the starter. I removed the starter relay and tried to bridge it with a wire to "jump" the starter... no luck.
I had an aftermarket (Avital 5305L) alarm/remote start in the car, but have since removed it thinking it may be some starter kill feature gone haywire.
Any thoughts?? I can't help but think it has to do something with that green temp light flashing.. but after searching, I can't figure out what that means.
haydenjowell is offline   Reply With Quote
Old 09-11-2023, 09:23 PM   #2
haydenjowell
FYI, it all turned out to be a grounding issue.
dead car, not starting, start
2007 Yaris Sedan part out JumpmanYaris Items for Sale by private party 61 07-05-2015 01:57 PM
Toyota Yaris 2007 car wont crank no start aamrkhan DIY / Maintenance / Service 0 01-19-2015 10:31 AM
Yaris 2007 Sedan in Canada David81 New YARIS Purchase Forum 16 09-09-2007 02:09 PM
