Old 09-26-2023, 02:32 PM   #1
Suey 1958
Drives: 2007 toyota Yaris
07 Yaris Front brake Pad Question
I have 240K (mostly highway) miles on my hatchback and it has never had the brake pads changed. I had tires replaced recently and asked the mechanic to look at the pads,... he said they were getting thin.
I have done many pad changes on various cars & motorcycles but not on the Yaris.
I usually compress the caliper with a screwdriver wedged between the pad and rotor for leverage. Is that method possible on this car? I just want to be sure I have necessary tools before I start. If a C-clamp is needed, will I need 3 0r 4 inch? Many Thanks.
Suey 1958 is offline   Reply With Quote
Old 09-26-2023, 04:07 PM   #2
First time hearing of screwdriver method on anything. Since compression is used to retract our pistons you can certainly try it. Personally I'd go for c-clamp since pressure applied is smooth and consistent. 6" clamp.
Old 09-27-2023, 05:38 AM   #3
Suey 1958
I will go with the 6 inch clamp, Thank You!
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
2007 Yaris Sedan Stop Lights Load Resistor Question crotermund DIY / Maintenance / Service 2 02-25-2015 06:30 PM
Yaris hatchback front seat question mr.white_hb Cosmetic Modifications (Exterior/Interior) 2 08-23-2009 04:04 AM
