Old 10-17-2023, 10:15 PM   #1
Bentobox85
Drives: 2012 Yaris Sedan
Passenger headlight and turn signal not working
The car is 2012 Yaris Sedan.
As stated in the title, the passenger side headlight and turn signal are not working.
If I turn on the high beams all the lights work fine so I know the headlight bulb itself is not dead. Also, when the headlights are switched on all the parking lights work, which are the same bulbs as the turn indicators so again, the bulbs are not the issue. I checked all the fuses and nothing seemed to be blown. All hazard lights, except for front passenger side work. Any help would be greatly appreciated
Bentobox85 is offline   Reply With Quote
Headlight problem persists after new bulb RMcG DIY / Maintenance / Service 11 09-22-2024 02:57 PM
Advice needed for replacing headlight bulb RMcG DIY / Maintenance / Service 21 12-06-2022 09:59 PM
2007 Hatchback Headlights won't turn off draining battery GLMaddawg DIY / Maintenance / Service 3 08-23-2020 03:23 PM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
