Old 11-09-2023, 01:59 PM   #1
Abebundance
Drives: Toyota Yaris
2014 Yaris Engine mounts
Hi there,
I'm possibly going to be doing this job for my partner as Toyota has screwed her around a few times. I just want to know how many mounts these cars have as I've read that there can be 4? I am mechanically minded and I mostly work on my car which is a Merc SL55, her car is a 2014 year model. I have a jack as well as power tools etc, would anyone also be able to provide the part numbers etc? her poor car has around 130k miles and has never had this job done. Thanks for your responses, I really appreciate it.
Abebundance is offline   Reply With Quote
Old 11-10-2023, 06:30 AM   #2
komichal
Yaris is not SL55, engine mounts are perfectly OK after 130k miles :P
Old 11-10-2023, 10:48 PM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Oh jeez, I've never done engine mounts in a Toyota in my life.
if its not f*cked, don't f*ck with it.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 11-13-2023, 12:38 PM   #4
Abebundance
Hi, sorry for the delayed reply, she has 152k miles and when the garage replaced her serpentine belt they stated the mounts are worn. She doesn't trust the garage as they did not tighten the engine mounts and it's screwed things up apparently, I did hear the belt squeal on start up... even in sunny Florida. Would I need to replace the transmission mount also?
Old 11-13-2023, 01:56 PM   #5
Belt squeal has absolutely nothing to do with engine mounts. The belt will need to be tensioned again shortly after install. Some brands of belts are also notorious for squealing no matter what you do. There is a 99.9% probability there is nothing to be addressed with either engine or tranny mounts. Their serviceable life goes well beyond the age and use of the car.
Old 11-13-2023, 03:00 PM   #6
Abebundance
I'll double check tomorrow when I go to visit. She took it to pep boys, so that would make sense why they'd say there is X amount wrong... Sadly they will try to fleece, I thought it could've been a belt tensioner personally. Either way, thank you so much for the response I appreciate it. I'll let you know tomorrow.
Old 11-14-2023, 08:01 AM   #7
We do not have a tensioner. Has to be done manually.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
2014 Mazda 3 Kal-El Off-topic / Other Cars / Everything else Discussions 32 11-08-2013 12:51 PM
Engine goodies for the Yaris botchilah Performance Modifications 8 01-28-2009 09:52 PM
