#1 |
![]() Drives: 2012 toyota yaris Join Date: Nov 2023
This may just be a shot in the dark, but i need some good advice and not the kind that tells me i should not have gotten the car!! I know how dumb this sounds, but I'm hopeful. I bought a 2012 Toyota yaris from a friend. The car has a new starter, throttle body, fuel injectors( I think they are on wrong)a new fuel pump, new battery, alternator was checked its good and the car still won't start unless you have jumper cables connected then it will try to start but goes off as soon as you release the key! Now, when I did that, it was when I noticed gas leaking around the new fuel injectors?! I was thinking of new coils and spark plugs next, but I'm just a girly girl and don't know how to fix fuel injectors or anything else cars Outside of oil changes and things like that. You tube come on handy on alot of things! I just don't have a lot of money to throw at this car right now so you best educated guess on what I should do next would be greatly appreciated, please and thank you in advance! I did buy a cheap obd2 scanner but I'm not sure if it's because mine is cheap it wouldn't read any codes with out the car running so no help there.
![]() ![]() ![]() ![]() Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Sounds like a battery issue to start with. You shouldn't have to jump it to start on a new battery. Is it charged? Have it tested. Maybe a fuse was blown if someone hooked up the battery backwards.
#3 |
The battery is holding a charge. Infact the car has power when you turn the key. The lights, ac and windows all work when u turn key to the to on
| Tags |
| not starting |
| 2012 Yaris Sedan. Dash lights, charging issues | PhoenixDriver | DIY / Maintenance / Service | 1 | 07-04-2016 07:04 PM |
| thewifesyaris - photo scavenger hunt | thewifesyaris | Photo-Video-Media Gallery | 0 | 03-01-2009 06:02 PM |
| Arkhangel - Photo-Scavenger Hunt | Arkhangel | Photo-Video-Media Gallery | 0 | 03-01-2009 02:03 PM |
