Old 11-29-2023, 03:54 PM   #1
mik36
Drives: VERSO S
YARIS 1.3 Vaccum from EVAP line
Gents
I had this strange issue in 1.3 petrol engine the evap line I can feel have a high pressure vacuum
When I open the tank cap I feel hissing noise feel pressure released
Is this normal
I was looking at the evap purge valve which has one line from fuel tank evap this line has got vaccum in it and when I removed the finder the rpm increases this line connected to black pipe in the valve there is grey one from this valve which i believe goes into engine
No codes.
When I remove my finger from evap line the rpm increases and LTFT jumped to 9
Any help to test cross check would be highly appreciated
mik36 is offline   Reply With Quote
Old 11-30-2023, 09:39 AM   #2
komichal
Whenever I remove the tank cap I actually do not hear hissing. I hear clapping as there is negative pressure in the tank that sucks air from outside and I guess there is some protective shutter that that makes the clapping.
Driving Yaris 2007 hatchback with 2SZFE 1.3 engine. Bought it in 2012, always behaves like that, never threw a code, never had any problem with this.
Old 12-01-2023, 01:09 AM   #3
Compeer
Drives: NCP90 TRD Yaris Manual
Originally Posted by mik36 View Post
Gents
Is this normal
No codes.
Normal, all my toyotas hissed like theirs vacume in fuel tank when i get gas, current yaris does it too. never ran it without cap on to notice any change,
Compeer is offline   Reply With Quote
Old 12-07-2023, 02:31 AM   #4
zoidberg444
zoidberg444's Avatar
Whenever I take the fuel cap off mine it always hisses as air rushes into the tank. I always assumed the EVAP system kept the tank under vacuum in order to draw petrol vapours from the tank into the intake to prevent them off gassing to atmosphere.
UK to Nordkapp in a Yaris
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
Which second hand Yaris to buy? 1.5-1.8 T Sport or 1.3 base? REs Third Gen Yaris General Discussion 5 07-06-2011 04:08 AM
